HELLO!
Q: Re: Mixer and Remixer on Tag Editor Virtual DJ 8
Q: Remixed BY Tag&Rename
I, have always tag My Music with "DJ.Rene"
on Tag&Rename But Does NOT Show In VDJ neither it SHOWS when I Tag on VDJ Tag Editor It Does NOT SHOW no were on TAG&Rename....ANYONE Please??? TNX
geposted Wed 09 Sep 15 @ 11:17 pm
what field are u putting "dj.rene" in?
vdj only supports certain fields u can reference this blog for more info https://virtualdj.com/homepage/wickedmix/blogs/5246/id3_Tag_Support_in_VDJ8.html
if you are using the remixed by field in tag&rename on the additional tab it will import correctly (I just tested it) just make sure you are tagging with id3v2.3 and everything should be fine.
geposted Thu 10 Sep 15 @ 12:43 am
