Currently on my win 8.1 machine i,m using asio 2.2.2 with denon DN-MC6000 version1 and ( currently VDJ 7), but having read
https://virtualdj.com/forums/203679/VirtualDJ_8_bug-report_Forum/Minor_bug_together_with_Denon_MC6000_Mk1.html
when using vdj8 should i be using WDM instead as per that thread and this?
https://virtualdj.com/wiki/DN-MC6000.html
Windows WDM audio instead of ASIO
2 deck hardware mixing (INT MIX):
Deck 1 | Speakers (MC6000) | Output 1&2
Deck 2 | Speakers (MC6000) | Output 3&4
If i use WDM will that then be fine for swapping (if needed) between VDJ 7 and VDJ 8 while testing out version 8
geposted Thu 10 Sep 15 @ 2:49 pm
Just try it. Id you don't have problems use the asio driver.
And no, it doesn't matter if you run v8 or v7 using the wdm driver.
geposted Thu 10 Sep 15 @ 2:55 pm
