A Deck is fine but B Deck will not play. I can load a song and it will start playing but nothing is coming out. Help??
geposted Fri 11 Sep 15 @ 3:16 pm
Are you using a controller? Does the B deck not work when pressing play on your hardware? Does it not work if you use the mouse and press play on the screen?
Have you attempted any mapping changes recently?
geposted Fri 11 Sep 15 @ 4:18 pm
