I'm having a hard time using my ddj sx with the vitual dj 8. when everything is turned on, it's states that their is a sound card but once I configure things it says that isn't a sound card to use. I'm pretty sure that my laptop has a sound card, but I do I set all this up to work?
geposted Sat 12 Sep 15 @ 6:48 pm
Please ensure you have installed the pioneer drivers. Then restart VirtualDJ
geposted Sat 12 Sep 15 @ 7:03 pm
[quote=jedi3000]I'm having a hard time using my ddj sx with the vitual dj 8.
when I try to use virtual dj with my ddj-sx a small box pops up and says new device detected. it also states, this device has a soundcard, do you want to use it? I check the box that says use soundcard, but I get a warning down on the right hand side that states - VirtualDJ - No Sound Card - Pioneer DDJ_SX ASIO - Failed to initialize ASIO driver.
what do I do now too fix this problem ?
geposted Thu 17 Mar 16 @ 9:42 pm
Close VirtualDj
Right click on the "Speaker" icon on the windows taskbar and select "Playback Devices"
Make sure that Windows are NOT using DDJ-SX as their default playback device.
If they are, set your laptop's internal soundcard as default.
Start VirtualDj and try again. This time ASIO should not fail.
geposted Fri 18 Mar 16 @ 7:50 am
Can a file be to loud to play? I notice that some of my track kinda fux up and down a little while they play.
geposted Sun 27 Mar 16 @ 7:56 pm
Thanx PhantomDeejay it worked. just trying too get things together.
geposted Sun 27 Mar 16 @ 7:58 pm
Your Issue has nothing to do with this subject, please do not hijack someone else's thread, thank you. You are free to start your own thread or search for a thread that deals with your problem.
geposted Sun 27 Mar 16 @ 8:56 pm
AMAHM,he's not hijacking as its the same guy who started this thread.overworked my man?
geposted Sun 27 Mar 16 @ 9:26 pm
Believe it or not, I actually read the whole thread, but did not notice who posted what. All I saw was a different subject. My bad. I will leave my post, so all can see.
geposted Tue 29 Mar 16 @ 4:41 am
