Can the Pioneer DDJ SB be mapped to control 4 decks in VDJ 8?
geposted Mon 14 Sep 15 @ 7:54 am
Well, in principle yes. You can even get a Novation Launchpad to do that, since it's all just midi commands, and the software takes care of the rest
So you can change some buttons to jump from deck A to C and B to D, and look at the screen for needed information
That would be a bit like for instance the DENOM MC3000 enables 4 decks use, but because the DDJ-SB is not layed out in a good way to do this, I don't think it will be very intuitive to use
geposted Mon 14 Sep 15 @ 1:09 pm
geposted Mon 14 Sep 15 @ 3:15 pm
I went through the setup and put in the code. When I selected for decks and I got a prompt that said impossible to use for decks...why?
geposted Mon 14 Sep 15 @ 5:19 pm
Did you check your spelling?
geposted Mon 14 Sep 15 @ 6:07 pm
Yes...I cut and pasted it in as well. The whole story is that I have mapped my V7's for 4 deck control once before and it worked fine. Just before I typed this reply... I opened VDJ8 and tried to select 4 decks with no controller attached and it still tells me that it is impossible to use 4 decks. I wonder if VDJ 8 4 deck use is specific to certain type controllers?
geposted Tue 15 Sep 15 @ 7:39 am
