Looking for reviews on this controller being used with Virtual DJ Will Version 8 natively support it also is there a mapper for it to use with Version 7
geposted Wed 16 Sep 15 @ 3:12 pm
according to the wiki -> https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
it works with both 7 and 8 natively
geposted Wed 16 Sep 15 @ 7:06 pm
I've used it with both versions. You have to update the firmware on the unit before you use it. If you don't, all kinds of strange stuff happens
After that I found it to be great with V8
With v7 you have to put the unit into "other software" mode (it's in the manual).
After that the only issue I found was that you can't really trust the leds showing vinyl and slip - it may be the opposite of what the lights are showing
Regarding effects there are a few things that you can get when using the pads in v8 compared to v7
But I wouldn't have any problems using the DDJ-SR for a gig with either version
My main hassle is with the feel of the controller itself.
I really don't like the feel of Pioneer transport (play/cue) buttons, so my DDJ-SR mostly sits on a shelf
But of course this is a personal preference, and would probably be the same with the DDJ-SX or a CDJ unit
geposted Thu 24 Sep 15 @ 10:01 pm
Would you like to sell the SR. I think my motherboard took a crap and fixing it might not be worth the price and time without it. I'm hitting up my busy season and need a new one.
geposted Thu 05 Nov 15 @ 9:54 pm
Unfortunately, forum rules prohibit the selling of anything on the forum.
geposted Fri 06 Nov 15 @ 6:24 am
Ok thanks, i realized he is in another country too.
geposted Fri 06 Nov 15 @ 6:38 pm
What controller do you use for vdj8?
geposted Thu 26 Nov 15 @ 5:00 pm
