I'm have a lot of trouble figuring out how to group both tracks on VDJ.
I want to have it where if I seek to a certain point in track #1, that the same will happen in track #2.
I use the "sync" feature for my mashups, and sometimes it takes awhile to find the sweet spot where both songs are synced. I don't want to lose the sync, when I try to play the songs from the beginning.
Hopefully I'm explaining myself clearly enough. Any help would be really appreciated!
geposted Fri 18 Sep 15 @ 3:56 pm
You could map a custom button with an action like this
Deck 1 seek -4 & deck 2 seek -4
Both decks should now seek 4 beats towards the beginning if you press the button.
A 2nd button with seek +4 will go the opposite direction.
If seek is not what you want try it with “goto -4“ instead.
geposted Fri 18 Sep 15 @ 7:04 pm
