Is there a way to keep the pitch lock function always activated in VDJ8 when adding a new song to a player? If yes can someone guide me in setting it up? I go in option and choose yes but when I add a new song to the player the pitch lock turns off. Is there a custom button that can be created to keep it activated?
geposted Fri 18 Sep 15 @ 6:55 pm
You could try
Deck x load & pitch_lock 1
geposted Fri 18 Sep 15 @ 7:00 pm
Where do I type that PachN? I was really good with VDJ7 but 8 is a bit different... I put it in actions in custom button but nothing happens. I tried deck 1 to replace the x
geposted Fri 18 Sep 15 @ 7:16 pm
put this on buttons you will use to load the decks with a song
Deck 1 load & pitch_lock 1
Deck 2 load & pitch_lock 1
Deck 3 load & pitch_lock 1
Deck 4 load & pitch_lock 1
etc...
select a song and hit one of the buttons :-)
etc...
geposted Fri 18 Sep 15 @ 7:23 pm
What your saying is I have to hit a button each time I load a song in a player?? Hitting Pitch lock on the skin I'm using does exactly that. I want pitch lock to stay on always like in VDJ7
geposted Fri 18 Sep 15 @ 7:27 pm
check if resetPitchOnLoad is active
this could cause the issue
set i to no
and pitchLock to yes
should be the setting you are looking for
works fine here
set i to no
works fine here
geposted Fri 18 Sep 15 @ 8:03 pm
bump
geposted Fri 18 Sep 15 @ 8:04 pm
Thanks RobRoy. It seems to be what I'm looking for. Thanks again.
geposted Fri 18 Sep 15 @ 8:07 pm
