Is the pitch fader resolution accurate in vdj8 as in pioneer cdjs? I have ddj-sx2 and i want to get the best of the pitch resolution i,any tips and tricks to have a higher pitch resolution in vdj8?
geposted Sun 20 Sep 15 @ 1:12 am
What do you mean by 'resolution'?
Do you mean the pitch range? I.e. 6%, 8%, 50%...
The bit resolution of the slider itself should be enough, but depending on the range how easy it is to set a specific value.
geposted Sun 20 Sep 15 @ 7:21 am
See here http://fr.virtualdj.com/forums/169447/PC_Version_Technical_Support/bpm_-pitch_range_0_01__increments.html
Also, you can use the pitchRange config setting to have a 1% range if you wanted - you can't do that with a CDJ :-)
geposted Sun 20 Sep 15 @ 12:54 pm
I think the ddj-sx2 is 14 bit,and setting pitch range on 12% gives accuracy 0.02 is the same as cdj which is good for me,that what i read in ur vdjpedia,i ll sure check this out on my controller thx
geposted Sun 20 Sep 15 @ 1:21 pm
There's still only one decimal place on the pitch?
geposted Fri 16 Oct 15 @ 7:32 pm
Thats a setting I believe.
geposted Sat 17 Oct 15 @ 9:24 am
