Hooking everything uo o my vontroller seems like a nightmare, Honestly I have spent 4-5 hours trying to be able to cue the next track in my headphones before bringing it in the mix. Im using a behringer UCA222 soundcard. I have my speakers hooked up thru the rca's and my headphones thru thw phone jack...under audio settings The master is listed as usb audio-codec 1&2, then I have the headphones as USB audio-codec 3&4....i get sound out of speakers and my cans but no cue sound.output is speaker and headophones, Card is splitter mono, but I also tried internal soundcard but with the same result. I even tried 2 soundcards using my laptops soundcard to try to cue4 from there and that doesnt work...man this is soooo frustrating please help me!!! Please!
geposted Wed 23 Sep 15 @ 8:15 pm
If I remember right that Behringer can only deal with the master when using a stereo pair.
Configure your internal soundcard for your headphones and just plug them into your laptop.
The Behringer driver is good and locks the usb port meaning your master output is fine, whilst you might get a little distortion on the headphone output. That is acceptable.,
USB audio-codec 3&4 = wrong it does not exist.
use..
Master USB audio-codec 1&2
Headphones onboard soundcard 1&2
You can also use a splitter cable and mono.
Master USB audio-codec 1 (mono)
Headphones USB audio-codec 2 (mono)
This is using mono and the Behringer, but you can just use your onboard sound card as well.
You don't need the Behringer when you have a splitter cable.
use..
geposted Wed 23 Sep 15 @ 9:33 pm
