Last night management handed me listings from Serato for reference of what went well in previous nights. I just sent them mine.
BUT!!! There are no BPMs in mine. How do I put BPMs in my playlist too? It's really pretty critical to follow the BPM flow of the night.
Thanks,
Jimmy
Thanks,
Jimmy
geposted Sat 26 Sep 15 @ 9:31 pm
Are you saying no bpms in the printout?
geposted Sat 26 Sep 15 @ 10:16 pm
Yes no BPM in my History.TXT file. I have the time in 24 hour format. then Name - Title. It would be great to turn that BPM column on. It's very important to see the BPM flow through the night.
geposted Sat 26 Sep 15 @ 11:27 pm
right click the headers and turn on bpm you will be able to view it in vdj as for export don't think that's going happen
you could use the History Converter utility by pachN look for it in the vdj8 other addons ... i think this does exactly what you want.
geposted Sun 27 Sep 15 @ 1:58 pm
The history converter will only help for your own playlist.
It won't help you for other users playlists because the BPM Info is read from The database. And if you don't have a Track at the Location shown in the history file, you won't get the db infos.
geposted Sun 27 Sep 15 @ 2:13 pm
I tried the History Converter (which is very nice) and the BPM column has nothing in it. I have BPMs turned on in my browser. Is there something I'm missing?
geposted Fri 02 Oct 15 @ 9:59 pm
In the tool you have to check the db fields you want to be exported. Open the list by clicking on the small arrow.
geposted Sat 03 Oct 15 @ 12:19 pm
