Hi,
So yesterday i selected a group of songs by "key" order
Then mixed a C# key song to an other one with the same key
but i know that song's key is like 1/4 note lower than the other one, so i pressed the "=" to match them and it does not work
both songs still have 1/4 note difference.
Is there a way i can make VDJ8 match the songs by key with accuracy so there is no difference in the note ?
geposted Thu 01 Oct 15 @ 12:55 pm
"with accuracy "
geposted Thu 01 Oct 15 @ 1:29 pm
VDJ assumes that the original file is in a key, there is currently no way to tell vdj that the key is C#+1/4 note. It can only work if it's either C# or D, not something in-between.
geposted Thu 01 Oct 15 @ 1:50 pm
Can key move work with decimals?
geposted Thu 01 Oct 15 @ 3:03 pm
Yes, manual moving of the key in finer amounts is possible.
geposted Thu 01 Oct 15 @ 3:06 pm
How is it possible to move it in finer amounts ? editing xml file ?
geposted Fri 02 Oct 15 @ 12:43 pm
Script
key_move +(or -)0.X
key_move +(or -)0.X
geposted Fri 02 Oct 15 @ 12:57 pm
I also have another question
Once i move the tone up 1/4 key to match the other deck, are this changes saved in the database file ?
geposted Fri 02 Oct 15 @ 2:05 pm
No it isn't saved
geposted Fri 02 Oct 15 @ 3:24 pm
oh, well.
At least i have the "key_move" edit option.
geposted Fri 02 Oct 15 @ 4:00 pm
