Trying to get the external drive (E) to stop going into sleep mode.
I have gone into device manager, root hub, power management.
Nothing is checked so the sleep mode should be off.
Still sleep in sleep mode.
Any suggestions please?
geposted Thu 01 Oct 15 @ 7:00 pm
There should be utility software for the drive that should have a selection to disable sleep mode.
geposted Thu 01 Oct 15 @ 8:16 pm
Often the power management is integrated on the hhd´s chipset. So any settings you make in the device manager will not take affect.
Try a tool like noSleepHD:
https://nosleephd.codeplex.com/
geposted Fri 02 Oct 15 @ 7:07 am
Did not find a disable mode on the drive. WIll give the program a try.
Thanks
Thanks
geposted Fri 02 Oct 15 @ 1:01 pm
Thanks Robroy, I need something like this.
geposted Fri 02 Oct 15 @ 3:52 pm
+1
geposted Fri 02 Oct 15 @ 4:38 pm
