I want video fx's to go with my color fx's on my DJM850
Noise,Gate and Crush,I already have the Filter done.
What video fx's would go good with those 3??
geposted Wed 07 Oct 15 @ 5:03 pm
Well there's the video gate, to go with gate.
What would be really good if transitions could work as effects and transition to white/black, I'd then go with saturate with noise and bit drain with crush.
But I'm just throwing ideas about.
geposted Wed 07 Oct 15 @ 6:40 pm
Thanks bro, I will try these all out when I get home.
geposted Wed 07 Oct 15 @ 6:48 pm
I've got a noise/scanline video effect if you want that.
geposted Wed 07 Oct 15 @ 10:54 pm
That sounds sweet!! I'll pm you.
And Thanks!
And Thanks!
geposted Wed 07 Oct 15 @ 11:16 pm
Man ive tried everything including Petes stuff and nothing goes good, argh!!
geposted Thu 08 Oct 15 @ 2:19 am
If you've got a suggestion for what you'd like then I can have a look at implementing it.
geposted Thu 08 Oct 15 @ 1:20 pm
Ok ill think about this over the weekend.
And ill take that plugin you mentioned earlier.
Thanks for the time...
geposted Thu 08 Oct 15 @ 3:16 pm
Crush I envisage a pixelator effect., (down sample the audio do the same with the video)
noise I'm imagining cinefilm distortions, colour fluctuations, cigarette burns, vhs tracking errors with the audio track veering into the video pickup, tape fade. Static.
Again just slinging idea about
geposted Thu 08 Oct 15 @ 3:59 pm
Yes Loco I'm right there with you!!
So Scott, do these sound doable??
Only thing I ask for whatever you come up with is that 50% kills the fx because that's how the color knobs work which I'm sure you already know, lol!!
geposted Thu 08 Oct 15 @ 4:13 pm
