Hi from France,
And first, sorry for my poor English...
I use VDJ8 since few days.
I like put video to the songs when I do a set.
With VDJ7, it was simple to do, but impossible to have the sound correctly associated to the video : not the same duration between the sound and the video, different bpm, etc...
With VDJ8, we are able to add video to a song and adjust them.
The problem is that we don't have any counter into the video editor, so it's difficult to have a good result.
You can have a good synchronization at start, but in the middle of the song it appear some delays.
Is it possible to help me ?
Thanks by advance.
Thanks by advance.
geposted Thu 15 Oct 15 @ 11:31 am
V8 has now the option to link a video with a mp3 via drag&drop ( similar to V7 but much better improved )
make sure you have videoCreatLinkOnDrop set to YES.
Load a mp3 file into a deck
drop a videofile into the video preview window ---> done
the new link function syncs as far as possible, loops if necessary and fit both trackts quite good to each other.
just give it a try
just give it a try
geposted Thu 15 Oct 15 @ 2:48 pm
Hello,
I know this solution.
But sometimes, i think that VDJ cuts to many times the video, with to many loops, and with no synchronization between the audio and the video (mouth of the singer).
So I try to add video in manual mode, but i don't know if it's possible to change the speed of the video or if it's only possible to cut it ???
Thank you.
Thank you.
geposted Fri 16 Oct 15 @ 8:27 am
In 'Video Overlays' you can select the video and select 'Stretch', then you can adjust the length by dragging the edges
geposted Fri 16 Oct 15 @ 9:02 am
This function modifies the lenght of the video without cutting the start and the end ?
So the video is read faster or slower, right ?
In this case, it is what I want !!
Thank you.
Thank you.
geposted Fri 16 Oct 15 @ 10:51 am
