In Virtual DJ 8.0 home private use, you cannot add skins etc. so why do I have to put up with the connection reminder every time I start up the program, I have found the "Hosts file" but there is no reference to Virtual DJ. Is there a way of stopping this nag screen ???? .
I previously posted as a query about the hosts file, I had read a post somewhere that said you had to edit the hosts file but that appears not to be the answer.
I cannot delete the previous topic.
geposted Sun 18 Oct 15 @ 12:31 pm
log in use your forum info .. i think that should do it
geposted Sun 18 Oct 15 @ 12:32 pm
You are not getting the point, I don't want to log in every time I start the program when I can' even use the downloadable files
geposted Sun 18 Oct 15 @ 3:21 pm
You'd only have to log in once though.
Anyway, you can also check the "Don't ask again" check box at the bottom of the log-in window.
geposted Sun 18 Oct 15 @ 3:41 pm
