how i can mapped machine mikro 2 with virtual dj 8
or i need some other gadget to make work with virtual dj 8
geposted Tue 20 Oct 15 @ 12:27 am
Well, it's not really a main DJ controller, but more of an add-on, isn't it?
So I don't think it's supported by VDJ
But there is a video here on how you can make VDJ8 interact with maschine:
https://www.youtube.com/watch?v=fREoSk4GoWE
geposted Tue 20 Oct 15 @ 8:05 am
Or rather Maschine interact with vdj.if you install the maschine software then you copy the dll (plugin) from the maschine plugin location,to vdj's sound plugins,then open on a deck (should be using 3 or 4 deck skin )...it kicks in when you start that deck. it's best to loop that deck with a track loaded and synced.also use simple maschine sequences,not too long.or it will clog up the buffer...in other words,dont load a colplete song that you normally run on standalone maschine.instead make loops for use with vdj...
geposted Tue 20 Oct 15 @ 12:22 pm
