Hello.
I am using a MC-6000 with a new Windows 8 laptop. Recently I noticed a buzz sound when I play a song through Virtual DJ using the Asio Driver midi channels on the mixer. When I play a song through Virtual DJ and use the headphone jack (computer soundcard) and use the Line 1 channel on the mixer there is no buzz. By process of elimination I think it's the Asio Driver. But I have reinstalled it twice and the buzz is still there. Has anyone experienced something like this?
The mixer is about 4 years old and I have the updated firmware.
geposted Thu 22 Oct 15 @ 2:57 am
Do you get the humming sound when the laptop is running battery or only when the laptop is plugged into the power supply.
geposted Thu 22 Oct 15 @ 7:20 am
I suggest you do avoid ASIO driver for DN-MC6000 and use WASAPI driver instead: it's more stable and no issue.
geposted Thu 22 Oct 15 @ 10:10 am
See this page on ground loops: https://virtualdj.com/wiki/Ground%20Loops.html
geposted Thu 22 Oct 15 @ 1:38 pm
I tried ground plugs and nothing changed. What is the WASAPI driver? Where do I get it?
geposted Thu 22 Oct 15 @ 4:12 pm
It's built in to Windows. Select it in the sound settings instead of Denon Asio
geposted Thu 22 Oct 15 @ 4:28 pm
This is a Denon issue, and it has been a problem for most of those that use the 6000. I have not been able to use the ASIO drivers for a whole gig. It may start out OK, but will sound like shet at some point. There are some that claim they use the ASIO drivers without issue. However, the vast majority of us use the WASPI drivers and keep it moving.
geposted Thu 22 Oct 15 @ 5:15 pm
The WASAPI sound driver doesn't come up as an option in my drop down.
geposted Fri 23 Oct 15 @ 3:40 am
Possible that t is named WDM driver.
The are the same.
The are the same.
geposted Fri 23 Oct 15 @ 8:38 am
