Hi guys,
I've recently bought a controller (MX4) after using vinyl for years, and I'm totally lost!
I installed VDJ7LE that came with the controller, then downloaded and installed VDJ8, then bought a PRO Infinity License. All seemed OK thus far.
Now, when I try and download any effects marked with 'PRO' or 'PLUS', I am unable to click the download button. I presume I'm using the correct license, and I've paid a monthly fee for the privilege of downloading the items a normal 'free' user wouldn't be able.
Can anybody offer assistance please? I'd appreciate it greatly!
geposted Thu 22 Oct 15 @ 6:51 pm
You are still showing as a LE user on this forum, hence the reason you can't download.
I take it you bought the V8 licence with the same username you are logging on with here?
Keith
Keith
geposted Thu 22 Oct 15 @ 6:53 pm
Hi Keith,
No - My VDJ8 program has a different log in name. If I log out of the forum, and log in with the same details as the VDJ8 program it might work? Lemme try...
geposted Thu 22 Oct 15 @ 6:56 pm
Umm...
Yes. I do believe I've won the idiot of the month award :)
Thanks for pushing me in the right direction Keith!!
geposted Thu 22 Oct 15 @ 6:58 pm
If you're paying a monthly fee then you haven't bought an Infinity license. It's a Pro Subscriber license.
Why did you buy it under a different name? [puzzled]
Best thing to do is contact support and get them to merge the accounts.
geposted Thu 22 Oct 15 @ 7:01 pm
Good question!
I've played vinyl for many years, and never looked at digital mixing before.
Before choosing the software I looked at controllers. I found a Hercules MX4 with 66% discount, so I just figured it would be rude not buy it. Before it arrived I registered on this forum, before upgrading to the subscriber pack once the machine had arrived - registering that with another username. I frequently use two names online, and on this occasion I mixed them up :)
My machine has me registered as AnimeUK, and I'm happy to pay the fee. I don't see myself moving back to LE - so unless I'm missing out on something, I can live without the old username :)
geposted Thu 22 Oct 15 @ 7:52 pm
Welcome top the dark side. It might be better to merge the accounts as Groovin stated, so there's no confusion down the road.
geposted Thu 22 Oct 15 @ 8:09 pm
