Hello,
I want to buy a led wall.
The software they use is Novastar Plus: http://www.novastar-led.com
I asked if they can tell me if Virtual dj will work, but they don't now what Virtual Dj is and how it works.
Is there somebody who knows if Virtualdj will work or can I only use Novastar for playing vids?
Greetings,
Anthony
Greetings,
Anthony
geposted Mon 26 Oct 15 @ 4:29 pm
I'm following this thread, because I also want to buy the (ADJ) LED wall with the novastar controller.
I have one person that states it can be used as a second monitor on your computer/laptop so if that's true, it can work with VDJ.
The most important thing is that the software has to have the possibility to scale to fit the screen size / resolution.
VDJ can scale, so when the demo wall is setup at the dealer, I will try it myself if no one knows the answer...
I also own MediaMaster and I know for sure I can use that, but I don't have a video IN on my laptop and the USB videocards with a incoming connection suck !
Even the manufacturer states I must not try to send VDJ video out to a USB videocard IN to use in Mediamaster.
So back to the question: I'm curious to if it will work direct from VDJ
geposted Tue 27 Oct 15 @ 12:57 pm
Since their "Sending Card" accepts a DVI-IN then all you need is your laptop to have a DVI-Output. In this case you proceed as usuall. You configure the DVI ouput as extended desktop and VirtualDj sends the video on the extended desktop.
http://www.novastar-led.com/products/synchronous-system/sending-card/26.html
geposted Tue 27 Oct 15 @ 1:09 pm
That's what I would expect indeed... So I really want to try it out. But buy to try is too expensive :)
geposted Tue 27 Oct 15 @ 1:29 pm
