Hi,
I've just purchased a subscription to virtual dj, and am having a few problems setting up my SC2900's with Virtual DJ 8.
The first one (deck 1) works fine, all the controls work, the led wheel around the jogwheel works, the song title and time etc. appear on the screen.
The second one (deck 2), all the controls work fine, but I don't get any led output around the jogwheel or anything at all on the screen (It just stays at the default of PC connected).
Doesn't matter which order I plug them in, or if I just have 1 connected, it's always the same.
The settings on each deck are exactly the same, apart from deck 1 is set to midi channel 1 and deck 2 is set to midi channel 2.
Does anybody have any clues as to why it's not working?? I've tried uninstalling and reinstalling, but that hasn't helped at all.
Thanks.
Thanks.
geposted Tue 27 Oct 15 @ 3:41 pm
Set deck 2 to MIDI channel 1 as well.
geposted Tue 27 Oct 15 @ 8:46 pm
Bingo!! Would have never thought to have them both set to the same MIDI channel.
Thanks!
Thanks!
geposted Wed 28 Oct 15 @ 8:33 am
