I had this problem before amongst a previous thread (which i could not re-allocate with a search)...aside from just going back to factory settings is there an easier way to remove "shop demo mode" so i don't have to go back and set my settings again in config?
All help appreciated
geposted Sat 31 Oct 15 @ 9:44 pm
edit setting.xml file in a text editor change this line
<shopDemoMode>yes</shopDemoMode>
to
<shopDemoMode>no</shopDemoMode>
alternatively delete settings.xml file but all settings will be defaulted this way
to
geposted Sat 31 Oct 15 @ 9:47 pm
You could edit settings.xml (look for the line <shopDemoMode> and change yes to no).
Snap!
Snap!
geposted Sat 31 Oct 15 @ 9:48 pm
Snap!
Snap!
I went to VirtualDJ Settings found that line <shopDemoMode>yes BUT i don't know how to change the yes to a no? how can i change/edit this xml document? I thought edit would be built in automatically or do i have to use another program for editing?
geposted Sat 31 Oct 15 @ 10:11 pm
The settings.xml file is just text - you can use Notepad to edit it.
geposted Sat 31 Oct 15 @ 10:24 pm
after i edit this command with notepad (just changing that part to "no") so that line is fixed, what do I do next after that step?
u gotta excuse me i'm not that great with computers.
and thanks for your time/patience
geposted Sat 31 Oct 15 @ 11:38 pm
save the file
start vdj
start vdj
geposted Sat 31 Oct 15 @ 11:59 pm
wickedmix wrote :
save the file
start vdj
start vdj
1)Ok saved this command to Notepad on Desktop: <shopDemoMode>no</shopDemoMode>
2) if I open this saved document (Notepad) from desktop i then opt to choose '"save as"
3) I then Search Virtual DJ Folder
4) Which sub-folder of VDJ should I then save it to? saving it as an .xml does not bring up "settings" as a sub folder only "all files" can i access the "settings" sub-folder? i'm stuck here which virtualDJ sub folder to save it to?
thanks again
geposted Sun 01 Nov 15 @ 1:09 am
nevermind prob fixed thanks!
geposted Sun 01 Nov 15 @ 3:28 am
How to change demo time in virtual dj
geposted Fri 06 Apr 18 @ 3:02 am
You mean the 10min test time on the free version?
You remove that by buying a license
geposted Fri 06 Apr 18 @ 4:44 am
