Can I use Rekord box to prepare my tracks instead of n vdj? would Rekord box? Curious if rekord box was better? is there anything to gain?
geposted Sun 08 Nov 15 @ 12:04 pm
depends on your hardware because they do not share information (CBG,cues,etc) as things are now.
geposted Sun 08 Nov 15 @ 1:13 pm
The databases of the various DJ and librarian softwares are not compatible.
Some software does allow a certain degree of importing data from another, but it's limited.
It's not a case of one being "better" than another. They all do very similar things. They're just not designed to be compatible with the competition (which is understandable).
geposted Sun 08 Nov 15 @ 1:36 pm
Thank you guys
geposted Sun 08 Nov 15 @ 2:08 pm
