I would like T to open the text box on "the master deck", and then "apply and close" the text box. Any help would be appreciated.
geposted Tue 10 Nov 15 @ 10:26 pm
+1
geposted Tue 10 Nov 15 @ 10:55 pm
I don't follow, what textbox?
geposted Wed 11 Nov 15 @ 12:20 am
There's no way to map hitting that Apply button that I can think of. Could certainly add one for you though :)
geposted Wed 11 Nov 15 @ 1:18 am
What apple button? Maybe I did not explain this correctly. I can map the "T" on the key board to open the "Text box" (you know, the text plugin in so you can put text on the screen), but it just lets me do a deck, not master. I would like to map it so it opens the text box for the master effect, then I type what I want, and then when I hit it again, it applies and closes. I don't need it to actually activate ( that's not a bad idea, but I don't want to be greedy, but you can do both, and let me decide). So any help from you guys would be appreciated.
geposted Wed 11 Nov 15 @ 7:50 am
Something like this?
deck master effect_show_gui "Text"
This would open it for the master. From within there, your T shortcut wouldn't work though (you need to be able to type :p )
It should probably be possible to use escape to close that window though. (And perhaps something like ctrl+enter or so to press apply)
geposted Wed 11 Nov 15 @ 8:33 am
Thank you, forgot about the typing. No way to make one key to open and close? I can do the apply.
geposted Wed 11 Nov 15 @ 6:11 pm
The command Adion have you will toggle the window open/closed :)
geposted Wed 11 Nov 15 @ 9:37 pm
It just opens (deck master effect_show_gui "Text"), it does not close. Is it because I'm using (\) as the key?
geposted Wed 11 Nov 15 @ 9:48 pm
Confirmed. Effect gui won't close.
Even with a non-text key.
geposted Thu 12 Nov 15 @ 8:29 am
Ah, it's because you're using a keyboard shortcut and once the plugin window opens that has keyboard focus.
geposted Thu 12 Nov 15 @ 3:18 pm
Ok, no problem, I can live with that. As long as I didn't put in the wrong script. The whole script thing is one of my short comings. Thanks for the help guys.
geposted Thu 12 Nov 15 @ 7:11 pm
