Hello.
I am using a Windows 8 computer. I have VDJ Pro version 7.4.6, and new Denon MC6000 MK2.
I am connected to my computer via usb, when I choose the proper settings in sound set up;
Inputs - Line In
Outputs - Headphones, master 1&2, headphone 3&4
Sound Card - Denon DJ Asio for DJ Controller
When I click apply, Error in the Asio sound driver. It acts like my computer is not seeing the controller, but if I change my sound set up
to;
Inputs - Non
Outputs - single out put
Sound Card - simple
I can push pause, play and cue on my mixer.
Any suggestions?
Inputs - Line In
to;
Inputs - Non
Sound Card - simple
Any suggestions?
geposted Sat 21 Nov 15 @ 4:06 am
Could be that it doesn't work with ASIO and simply use the MC6000 as a sound card
I would do this:
- Try uninstalling all asio, all Denon drivers and make sure there is no ASIO4ALL installed
- Then install the all drivers/ASIO driver for Denon MC6000mk2 again, and make sure when the unit is connected that all is found/installed ok
- Then open VDJ and set it up to use the MC6000 correctly
I would do this:
geposted Sat 21 Nov 15 @ 4:41 pm
