overall improved stability?
Um what exactly, i don't really want to upgrade to 8.1 with all its clutter, so what am i missing re overall improved stability
geposted Mon 23 Nov 15 @ 1:17 pm
v8.1 - build 2582 (2015-11-20)
-Fix slicer length not restored on restart
-Fix systray icon not removed on exit on windows 10
-Add 'Content Unlimited' text above content unlimited search results
-Fix issue with random video transition getting stuck on Droplets transition
-Add 'Restore' option for internal plugins moved to Ignore folder
-browser_sort action updates second order sort (same as clicking column headers)
-fix invert_deck for deck 4
-fix bug when adding a recursive folder with filter folder inside to sideview
-fixed deep recursion bug
-browser_scroll can be used with percentage (browser_scroll 50%)
-fix possible lockup on internet downloads
-sampler_group_volume ghost slider fix
-Genres can also be delimited by / now, not only ;
-Fix for HID encoders when overflowing
-Midi bar output accepts boolean as well (for on/off support)
-New VDJScript verb 'is_audioonlyvisualisation' which will return true if the deck currently has the audioOnlyVisualisation active
-Fix empty picture sometimes when video is loaded but busy seeking
-Fix empty picture sometimes after seeking video back to beginning
-Allow RPM to be set to '4 beats' so that one rotation takes exactly 4 beats
-Prevent song from stopping when loop is set past the end of the song
-Saved loop commands with no parameter now act on the first saved loop slot
-Can no longer save a loop with ID 0
-Fix file deletion on mac os x 10.7
-Loop position remains quantized when automatically moved whilst quantize_loop and loopAutoMove are both enabled
-Fix some rare crashes when refreshing the effect list
-Fix crash when dragging a delimiter from cover flow
-Fix video editor crash
-Fix memory leak when aborting song load of a non-analyzed song
-Fix config window saying 'not logged in' when user was logged in but had no user name (google login)
-Fix sound setup showing warning triangle when user has Plus license and external mixer output, even though license supports it
-Fix rare audio crash when soundcard samplerate is different from internal samplerate
-Fix crash using controller to switch through browser lists
-Add support for jog wheel enable bit for HID controllers (for Pioneer CDJ's)
-Fix skin button getting stuck in mouse down state if it closes an effect interface
-Fix various messageboxes stuck behind config window on Mac
-Fix loop_select on encoders when moving very fast (+2/-2 as parameter)
-Fix factory default mapping not selectable
-Shift all cues excludes beatgrid
-Slidshow can play video samples
-Sample dropped in list view starts at first row instead of second
-Serato root folder can be re-ordered
-Shazam integration
-Improved cloudlist features
-Shazam integration
geposted Mon 23 Nov 15 @ 2:00 pm
Thanks, i,ll leave it a month or two.
geposted Mon 23 Nov 15 @ 2:07 pm
edit sorted
geposted Mon 23 Nov 15 @ 2:17 pm
The above list doesn't list all the stability improvement, it mostly lists changes in features or specific fixes.
We also fixed a lot of potential uncommon crashes and bugs.
And the new features do not take any resources until you actually open the folders concerned (and you can hide these folders if you don't need them).
So we do recommend to update to 8.1, even if you do not intend to use the new features.
geposted Mon 23 Nov 15 @ 8:28 pm
dumb question but 8.1 is only on beta build correct?
geposted Tue 24 Nov 15 @ 12:32 am
Not anymore... Version 8.1 is the current stable version (8.1 b2582)
https://virtualdj.com/download/
geposted Tue 24 Nov 15 @ 3:47 am
I've been using v8.1 b2585.1086 for a couple of days.
Does this mean the link you've posted is the Public release?
geposted Tue 24 Nov 15 @ 1:50 pm
Yes looks like a full public release now
geposted Tue 24 Nov 15 @ 2:56 pm
b2582 is public
b2585 is a earlyAccessUpdate, which can be activated in Settings/ Options
geposted Tue 24 Nov 15 @ 3:26 pm
Just downloaded and installed v8.1.2586 it's working fine. :)
geposted Wed 25 Nov 15 @ 12:01 am
Where can i download previous version 8 releases?
geposted Wed 25 Nov 15 @ 7:48 am
geposted Wed 25 Nov 15 @ 8:03 am
cheers
geposted Wed 25 Nov 15 @ 8:06 am
PhantomDeejay those options don't give these though https://virtualdj.com/wiki/VirtualDJv8.0builds.html
I want to put a version i have on one laptop on another backup as i have had no issues with that
geposted Wed 25 Nov 15 @ 8:17 am
just check the build on the one laptop, select the build number out of phantom´s link and download ?
geposted Wed 25 Nov 15 @ 8:51 am
I can only see 6 builds on that link and mine isn't on it
geposted Wed 25 Nov 15 @ 9:00 am
what is your exactly issue with the current build please ?
geposted Wed 25 Nov 15 @ 9:42 am
If you still have the old build you want a backup of installed on your laptop, just copy the virtualdj8.exe from there.
geposted Wed 25 Nov 15 @ 9:51 am
Found it on a backup drive.
I,m sure nothing is wrong with current build, but as i know my current config works, i don't feel the need to change, a bit like i,m happy with win 8.1 and not using win 10.
I am putting current version on too but i want to know i can fall back at a gig if needed when i do try 8.1
geposted Wed 25 Nov 15 @ 10:17 am
