Taking suggestions on which tablets I should check out for use with vdj. I'm not interested in the remote and im not looking to mix video. So a low to mid range priced tablet will suffice. I think.
I didn't get any feedback from any archos users but I did run across somebody seeing one in use once. But that was all. So I'm looking for a tablet, the smaller the better.
geposted Sat 28 Nov 15 @ 7:46 pm
VirtualDJ will run on Win and Mac OS only
IRemote is designed for tablet use
geposted Sat 28 Nov 15 @ 9:23 pm
Next caller
geposted Sat 28 Nov 15 @ 10:28 pm
Surface Pro is as good as your gonna find since VDJ won't run on a basic "tablet". The tablet has to be running windows 8.
Caller, I'm listening.......
geposted Sun 29 Nov 15 @ 11:32 am
Basic tablets with full windows 10 start to pop up though.
The Onda V820W CH is one example at the low end.
It runs VirtualDJ quite smooth, although you'll have to find a skin more suited for an 8" screen.
geposted Sun 29 Nov 15 @ 1:11 pm
be careful when choosing one of these tablets some charge through the only available USB port which will put you in a bind if u need to charge and use any USB devices with it
yes i have one that is that way and it sucks.
geposted Sun 29 Nov 15 @ 1:47 pm
My Wife has got a Lenovo thinkpad 8. 2 gb ram version.
I didn't test it live but it runs vdj quite good.
You can get a used one for about 150 Euro.
geposted Sun 29 Nov 15 @ 2:19 pm
That's what I'm talking about, forum. Great input!
geposted Sun 29 Nov 15 @ 9:00 pm
I have a surface pro 3 in 8Gb ram and VDJ runs with no issues at all
geposted Sun 29 Nov 15 @ 11:24 pm
hi will a tablet run with a controller
im looking at getting a tablet
geposted Sun 06 Dec 15 @ 9:51 pm
There are several controllers that run using I pads, please check Pioneer's website first, and then check other manufacturers.
geposted Mon 07 Dec 15 @ 9:35 pm
