Hello
I am searching a skin like or exactly serato.
in the downloads here, there is nothing.
has anyone something for me?!
geposted Wed 02 Dec 15 @ 3:36 pm
It's not possible, see rules below regarding submitted skins. Any that directly resemble Serato are not approved.
SKINS RESEMBLING OTHER SOFTWARE -- If you are submitting simply 'hacks' of other software then the skin must be dramatically different from then original software's look. It can not be a simple color change, just moving of a couple elements, or adding some text/graphic on the skin. There are more and more submissions that are starting to occur that are direct resemblance of the other software. Please do not spoil the flexibility of being a bit creative to where we have to impose more stringent requirements.
geposted Wed 02 Dec 15 @ 3:44 pm
If you really must hide the fact you're using VDJ, why not simply use Serato DJ instead?
geposted Wed 02 Dec 15 @ 6:34 pm
@ paulinio81
the original skin of serato has sure some kind of copyrights perhaps.
So i guess it is pretty unlikely you will find one that looks exactly the same.
You are not satisfied with the suggestions you got in the german forum ?
geposted Wed 02 Dec 15 @ 7:24 pm
Maybe he don't like the way you German guys talk. I can't stop laughing, thank you.
geposted Wed 02 Dec 15 @ 8:24 pm
paulinio81 wrote :
Hello
Pm me and I'll hook you up.
geposted Wed 02 Dec 15 @ 9:13 pm
Have you seen this one.
geposted Wed 02 Dec 15 @ 9:22 pm
