My question is thusly:
Currently, I have VDJ 7 Broadcaster. I broadcast to two different stream servers with my live sets. According to the advertisement, this is eliminated, IF I understand correctly. The two sites I broadcast to have their own stream URLS (I broadcast into the virtual world SecondLife using two different streams). Will using VDJ8 prevent me from broadcasting to those two separate URLS, thereby, basically saying I'm done for? I guess I don't understand the purpose of having to 'broadcast' to the VDJ website, as they already have stream URLS that they pay for already. Is there a way around this, or, am I basically screwed if I move to VDJ8? And, please, serious replies and advice only. I won't be buying VDJ8 if it means I can't use a stream that the "virtual clubs" I DJ at pay for already, or if it's a technical hoopfest to jump through so that my listeners can listen to my sets.
geposted Thu 03 Dec 15 @ 8:03 am
VirtualDJ 8 still allows you to broadcast to a shoutcast or icecast server of your liking.
Just go to options, broadcast and select radio server.
There you can enter the server's details.
I'm not aware that you can broadcast to 2 servers at once even in vdj 7 though.
geposted Thu 03 Dec 15 @ 8:25 am
1. Can someone please tell me why when I'm broadcasting in PC to PC Direct mode @ https://virtualdj.com/broadcast/captainaudio That VDJ says: loading your broadcast and I can never play or hear the audio?
2. Does anyone know where the output audio can be heard while using VDJ8 "Radio Server"
Thanks, Geoff in Cincinnati
geposted Tue 08 Dec 15 @ 9:30 pm
I paid for the karaoke video subscription(19.99} and want to know hoe to utilize it.
geposted Sat 27 Jan 18 @ 9:09 pm
Make sure you have it in the license pane under settings in vdj
The go to the online folder in vdj, choose the karaoke part, search, download to deck and play
geposted Sun 28 Jan 18 @ 9:35 am
