Hi guys,
Just wondered if VDJ8.1 had addressed the problem whereby you had to connect both CDJ's at the same time in order to use them with VDJ? I'll be taking over from a DJ who uses the club's CDJ900NXS with Traktor so it'd be great for any advice on a seamless transition.
Craig
Craig
geposted Thu 03 Dec 15 @ 11:09 am
You don't have to connect them both at the same time.
To use the audio from the second one, you may have to go into audio config and click 'apply' to connect it though.
geposted Thu 03 Dec 15 @ 11:34 am
He might be talking about the Aggregate Device configuration on Traktor... just my guess.
Bring CDs and/or USB sticks with music so it would be worry free (All range of BPM of you want transition from his last song).
While the CD/USB stick is playing, the other DJ can exit Traktor and you can start hooking up.
Note: Make sure you have the latest driver's for the CDJs (and/or the mixer DJM if USB enabled - should be on another topic if you will use it).
geposted Thu 03 Dec 15 @ 11:27 pm
Anyway, here are my tips:
Bring CDs and/or USB sticks with music so it would be worry free (All range of BPM if you want transition from his last song).
