can i upgrade from version 7 to 8? i can't find anywhere to do it
geposted Fri 04 Dec 15 @ 12:16 pm
https://virtualdj.com/download/
Not sure if your Cue licence will entitle you to a free upgrade but if you install version 8 and sign in you will find out.
Keith
Keith
geposted Fri 04 Dec 15 @ 12:17 pm
I have logged into it but it doesn't say much to be honest, its not asked for a license key or anything, its just logged me in...
geposted Fri 04 Dec 15 @ 12:23 pm
You don't need a licence key, just use your forum login.
If you go to the licences tab in config you will see the options there.
geposted Fri 04 Dec 15 @ 12:39 pm
mine looks exactly like that picture but with me logged in at the top of that box... so do i now have the full version?
geposted Fri 04 Dec 15 @ 1:03 pm
If you are logged in look at the licence section to see if you have Pro Infinity.
geposted Fri 04 Dec 15 @ 1:04 pm
im logged in and it looks exactly the same as the picture you posted??
geposted Fri 04 Dec 15 @ 1:08 pm
In which case I would assume your Cue licence doesn't carry over to V8. You will need to buy a new licence or a subscription. There was an option to crossgrade from Cue at a reduced price some time ago but I don't think that offer exists any more.
geposted Fri 04 Dec 15 @ 1:32 pm
@djbillyg you could try entering your Cue serial number into the box provided.
Also it's worth dropping support a line and asking about your options.
geposted Fri 04 Dec 15 @ 9:56 pm
CUE license owners are not entitled to a free upgrade to VirtualDJ 8.
You will need to purchase a VirtualDJ Pro Infinity license. https://virtualdj.com/buy/
geposted Fri 04 Dec 15 @ 10:04 pm
