How can I remove some CU/net search song that I delete in my Database, the name of the songs now have number & letter (in the tags ) using removing missing files don't work and I can't group them all to delete them.
geposted Sun 06 Dec 15 @ 10:29 pm
You should have deleted those files using VirtualDJ (with right-click->File Operations->Delete. This should have removed those files from the Database (Search ) as well.
But at any case, remove files from Search DB should work. Just tried, deleted some cached files using Windows Explorer, then opened VirtualDJ, chose Remove missing files from Search DB and then those files didnt show up as Search results anymore.
Note also that by removing files from Database, will not update un-monitored folders and Playlists. Those will have to be manually updated.
geposted Mon 07 Dec 15 @ 12:26 pm
Think I got when I DL CU I put a Color on it, so I look under non color and seen the song I was look for but didn't use,and remove from database didn't work
geposted Mon 07 Dec 15 @ 5:06 pm
Khepri61678, I leveled your post up because;
1) It has absolutely nothing whatsoever, to do with this subject, meaning you are hijacking the thread.
2) It was so vague, that no one will be able to help you, unless you are more specific. Please start your own thread, and explain the issue you are having, thank you.
geposted Mon 07 Dec 15 @ 5:32 pm
