Hi,
I have a line in and line out - Virtual DJ works well and I can process the line in, do a few tasks and make it come out of the line out.
What I am looking at doing is automating a few things - I ideally need it so that if nothing is heard on the line in for ~10 seconds, it will automatically start playing a playlist and fade in. When there is something on the line in, it will automatically start fading and stop the play list... It can just fade in/fade out, no actual need to start the playlist from the beginning or stop it.
I first looked at scripts, but, I don't think that is correct as that appears to be more for Macros. I was wondering if building a plugin is the only way to do this, or, is there an easier way already built in?
Thanks
Thanks
geposted Mon 07 Dec 15 @ 9:19 am
You could have automix on one deck and line in on the other deck.
It is not impossible to create a script that would watch the vu meter of the line deck and count how long it's silent, then start fading to the other deck.
geposted Mon 07 Dec 15 @ 9:27 am
