Hi.
Strange one this. mobile set up has always been, macbook wih vdj8, denon dn-hc4500 controller, analogue mixer, powered mackie speakers and of course various led lights via a controller. Last three set ups i've had, through my speakers on start up, what can only be describes as strange "alien echo" and crackling inference through the speakers. Not all the time, just occasionally, but throughout the night, like a "whoohohohohoho" metallic type 1950s b-movie alien sound. Ive change the distribution of plugs so one power source isnt overworked, i've ground looped alll the mixers audio inputs and all power comes via leads that have surge protectors. Totally at a loss. Anybody have ANY ideas or pointers?
Cheers in advance.....
geposted Tue 08 Dec 15 @ 1:22 pm
You should be very careful, because I have heard about this "Alien Echo" before. This is a known issue, often called a close encounter, of the second kind, where they are tracking you. Your coordinates have been acquired, and they are pretty close to going to the next level, which is abduction. As you know, during this stage, you will be subjected to experiments, where they will insert large probes into all of your ...............
oh wait...............................I think I saw that in a movie.
I would set up at home, see if I could reproduce. It sounds like a loose or bad cable. Also try without surge protector.
geposted Wed 09 Dec 15 @ 11:10 pm
