Hi Folks,
I am new to VirtualDJ (worked before with Djay by algoriddim) and want to achieve the following:
1) disable the BPM Syncing when "mix_now" Crossfading between Deck 1 & 2:
I have disabled "Smart Play". I have set "autoBPMMatch" to NO. I have set "resetPitchOnLoad" to NO.
But the BPM are synced whenever I am crossfading a song. How can this issue be solved?
2) How can I set the time of the crossfading "mix_now" to a specific time (default is something between 3 and 4 seconds) - desired is 7 seconds.
Thanks for any advice!
Kind Regards,
Stefan
Kind Regards,
Stefan
geposted Thu 10 Dec 15 @ 9:19 pm
1. Use mix_now_nosync instead of mix_now
geposted Fri 11 Dec 15 @ 4:54 am
Great - Thanks a lot!
geposted Fri 11 Dec 15 @ 8:59 am
