Hi folks,
I have been using Virtual DJ 7 Pro on my laptop, which runs Windows 10, and it has suddenly stopped opening. It has been working fine up util today, I switched my laptop on and attempted to open VDJ7 but all I got was the little circle loading icon. I have uninstall and reinstalled, I have tried opening the .exe file in program files but it is still the same.
Can anyone shed any light on this?
Cheers
Matt
Cheers
Matt
geposted Fri 11 Dec 15 @ 6:24 pm
Why do you use vdj7 ?when vdj8 is out !
vdj 7 is not supported any more !
move to vdj8 !
move to vdj8 !
geposted Fri 11 Dec 15 @ 8:17 pm
He can use any version that he wants, that is not his issue. We still provide help on the forum, for both versions. I don't know what your issue is, but bumped you up so others can see it. You may also want to try support.
geposted Mon 14 Dec 15 @ 6:30 pm
Hello all!
I've been having the same problem as well. I prefer Virtual Dj 7 and it doesn't work anymore. ???????
geposted Mon 14 Dec 15 @ 7:58 pm
move to vdj8 !
move to vdj8 !
Each to their own, you use the software which you feel benefits you the most is the answer.
And you've guessed it, I still use v7, but that's another story.
geposted Mon 14 Dec 15 @ 8:06 pm
Paul, since you are still using 7, can you offer any assistance to the OP?
geposted Mon 14 Dec 15 @ 9:31 pm
Hey Rick and mjb212, I'm using v7.4.1 but I wouldn't have thought that would make much difference, what is more likely is using windows 10, I've seen a few guys on the forums having problems with W10.
It's a bit tricky to say that could be the problem because others are sailing along nicely with W10, mjb have there been any updates on your machine that have happened since the last good opening of vdj, if so, try a system restore to your last good opening point, check your drivers is another place I'd be looking at.
Sorry it's all a bit vague and clutching at straws but I have no experience of W10. If I come across something that could be relevant I'll post back here guys.
geposted Tue 15 Dec 15 @ 1:13 am
