I no longer have the ability to delete songs in the sideview panel with the "delete" key. I went through and changed my keyboard mapping on VDJ 8.1 to reflect my personal preferences, but I don't have anything mapped to the "delete" key. Any ideas of what happened or how to restore the function of that key? Thanks!
geposted Fri 18 Dec 15 @ 7:53 pm
So, you click-select a track in sideview (automix , Sidelist etc) using mouse and then the DELETE key from your keyboard doesnt remove the selected track ?
Just tried and works fine here.
geposted Sat 19 Dec 15 @ 12:06 am
That is correct. I think I messed something up while configuring my keyboard mapping.
geposted Sat 19 Dec 15 @ 12:52 am
You should be able to switch back to the default mapping to test.
geposted Sat 19 Dec 15 @ 1:15 am
ahh you are on Mac. Well, on Mac the DELETE key is actually the BACKSPACE in Windows. Thats why the deletion doesnt work for you.
Try holding down the FN key and then press the DELETE
geposted Sat 19 Dec 15 @ 4:32 am
My FN and delete doesn't work I have to use OPT and Delete. Try that?
geposted Mon 21 Dec 15 @ 7:02 pm
if you want to custom map it: Go to CONFIG->CONTROLLERS tab. Highlight KEYBOARD. Now click in KEY LEARN box and press your DELETE Key. Now in the ACTION box Enter: browser_remove
geposted Mon 21 Dec 15 @ 9:45 pm
Thank you for this. Now, is there a way to restrict it to only deleting from the sidelist pane? As it is now, it will delete a song if highlighted in the main browser window. Not a huge problem, as it seems that the playlist will repopulate if you click on it again, but could cause some issues.
geposted Tue 29 Dec 15 @ 6:01 pm
browser_window 'sideview' ? browser_remove : nothing
geposted Wed 30 Dec 15 @ 10:02 am
