I have this problem, that some content unlimited song won't load. It says error on deck 1.
It's like only 20% of the songs will load.
I really need this working, cause I use it alot.
I've tried this on 2 computers and had the problem on both.
geposted Fri 18 Dec 15 @ 8:44 pm
Can you give me a few songs that won't work for you?
geposted Fri 18 Dec 15 @ 9:46 pm
Do the songs have purple or red icons? If they are purple then they are from Netsearch, and you'll need to enable earlyAccess to get the latest update which updates Netsearch.
geposted Fri 18 Dec 15 @ 10:40 pm
I'm having the same problem here. Most of the clips are from VEVO. Can't download to cache. Any solution?
geposted Sat 19 Dec 15 @ 9:46 pm
geposted Sat 19 Dec 15 @ 10:52 pm
Yes, the purple ones doesnt work. I enabled earlyAccess from options and now it seems to work! Thank you!
geposted Tue 22 Dec 15 @ 6:59 pm
