When using POI editor and saving your project, it saves it as VDJ Edit.
I copied the saved project to my backup system, but it it keeps saying file error
and will not open.
Do you need to repeat the steps on the second system, or is there a way to copy it over?
and will not open.
geposted Tue 22 Dec 15 @ 8:58 pm
I guess it probably needs the original file too...
geposted Tue 22 Dec 15 @ 10:00 pm
POI Editor doesnt generate any edit file.
Probably you mean Track Cleaner or Video Editor.
And yes, the edit file is just a file with some info/actions, doesnt contain the "media" (sound or video) and needs the original file in the same directory as the edit.
geposted Wed 23 Dec 15 @ 12:22 am
My mistake. I previously used Track Editor to have a certain part of the track repeat 4 beats until I wanted to end it.
I tried to do the same thing in POI Editor, except I used the file made in track editor instead
of the original track. That was my error.
I can get it to work in POI Editor, but it will only repeat one time.
geposted Wed 23 Dec 15 @ 2:32 pm
