I'm using a Pioneer DDJ-SX2 and previously had control of the left deck. I was able to "Scratch" and manipulate tracks (via the jog) like normal, until just recently. Neither my mouse pointer, my touch screen, or my controller will allow me to scratch on deck A. The sides of the jogs on my controller still allow "nudging" or speeding up and slowing down like usual though. The RIGHT DECK works just fine, like normal. Can Anyone help? I can't find any solution while browsing through the options/configuration tabs. It seems like it would be just an on/off type of selection from somewhere. I am using v8.1 as of now. (This problem occurred prior to this update.) I use the VDJ 7 two deck skin.
PLEASE HELP!!! I Have A Gig Tomorrow/Tonight!!
SETUP:
Pioneer DDJ-SX2
VDJ 8.1
Windows 8
Sony Vaio !3.5" ,8G RAM, 8GB SSD, 500GB HD
SETUP:
Pioneer DDJ-SX2
VDJ 8.1
Windows 8
geposted Wed 23 Dec 15 @ 6:08 am
Enable Vinyl mode for the deck that's not working.
SHIFT+SLIP button on SX2
geposted Wed 23 Dec 15 @ 6:32 am
Be sure that you don't have enabled some skid or brake effect on this deck.
geposted Wed 23 Dec 15 @ 2:35 pm
Thanks guys for your help. It is gratefully appreciated!
geposted Wed 23 Dec 15 @ 10:07 pm
