I downloaded it and open the installer. I can't change the install location for one thing and furthermore after install the files are nowhere to be found.
I was using VDJ 7 but it wasn't working with my login as I couldn't get the subscription working and use my DDJ SB for more than 5 minutes.
Can anyone help with this situation? I paid for a monthly subscription but so far can't use it since I don't have a working copy of Virtual DJ installed that will work with my login.
TIA:)
TIA:)
geposted Sat 26 Dec 15 @ 12:35 pm
Virtual DJ 7 downloads fine. But my login doesn't work with it so I still only get 5 minutes of use with my SB. If it helps I'm running a Macosx with Mountain Lion 10.78 if I'm not mistaken.
geposted Sat 26 Dec 15 @ 12:53 pm
Hi
PC or mac? Which os version? Why do you want to change location? Which Build of virtualdj you have (see properties)?
geposted Sat 26 Dec 15 @ 12:55 pm
Check your OS permission in write when you install the software.
geposted Sat 26 Dec 15 @ 12:59 pm
8.1.2578 is the version
Don't wanna change the location I just wanna see where it specifically installs to so I can find the file.
geposted Sat 26 Dec 15 @ 1:11 pm
FYI the subscription license will only work with VDJ 8.
VDJ 7 used a serial number system for registration (which required a full purchase), whereas VDJ 8 uses a login system.
geposted Sat 26 Dec 15 @ 1:44 pm
You should see VirtualDJ in the "Applications" folder.
geposted Sat 26 Dec 15 @ 10:49 pm
When I download it, it doesn't come up. Should I remove all my other virtual DJ files?
geposted Sat 26 Dec 15 @ 11:26 pm
Well I cleared and deleted everything and reinstalled now and it installed finally but now VDJ is saying it cannot connect to the servers and I gotta login to use the thing :/ Hmm now what.
geposted Sat 26 Dec 15 @ 11:30 pm
Are you using a PC?
It may be an issue with your hosts file.
There is a tool you can download to fix that.
https://virtualdj.com/plugins/download.php?addonid=80191
EDIT:Sorry, I just saw where it says your in a MAC
geposted Sun 27 Dec 15 @ 7:27 pm
There's a Mac version too https://virtualdj.com/plugins/?addonid=80192
geposted Sun 27 Dec 15 @ 7:49 pm
Don't delete all files and settings, when it asks you.
geposted Sun 27 Dec 15 @ 8:29 pm
Had the same thing happen to me except it was corrupting my other install of VDJ.
I trashed everything and moved my settings, skins, plugins, etc,etc to a different location and then VDJ finally installed.
And yes I to was on a Mac when this happened.
geposted Mon 28 Dec 15 @ 3:36 pm
