Hi, I bought a used Mixtrack which came with used software. When i download Virtual DJ it asked me to enter the serial number, i got a Protection Error message, also when i try to register it on Virtual DJ it says serial number already registered. is there any way i can get a new serial number?
geposted Tue 29 Dec 15 @ 8:32 pm
I don't think so.
As far as I know the virtual dj license is not transferable, so you can't buy/sell a "used" license together with for instance a controller
geposted Tue 29 Dec 15 @ 9:07 pm
You must have downloaded VDJ 7 if it's asking for a serial number.
VDJ 8 is the latest version and doesn't require a serial number. You just need to buy a license.
geposted Tue 29 Dec 15 @ 9:17 pm
Unfortunately, the above answers are correct. The license and serial numbers, are not transferable. You have a few options. You can buy a controller license that will allow you to use that controller only. A subscription license, that will allow you to use any controller, but you have to pay every month. Or buy the Pro Infinity license, that allows you to use any controller, and never pay another penny, all upgrades are free. But wait, there's more. If you buy in the next 10 minutes (which means anytime), you will get both, versions 7 & 8, shipping and handling included. And as an added bonus, both of the versions can be on the same computer, at the same time. In order to take advantage of this huge offer, you must order now, quantities are limited. Operators are standing by to take your order.
geposted Wed 30 Dec 15 @ 12:14 am
