I cant find anywhere option just to hear master channel.I hear two channels when slider is in middle position but i want to hear just master out.Can it be done?
geposted Tue 29 Dec 15 @ 9:29 pm
What do you mean by two channels? Do you mean two decks, as in, you hear deck 1 and deck 2 coming out of the master at the same time?
geposted Tue 29 Dec 15 @ 11:51 pm
Yeah,i mean i can hear 2 decks when is slider in middle position.In serato dj when you move slider to the right,u hear only 1 deck which is going to the main mix so u can hear how is your mix going to master channel.I hope you understand what i'm tryin to explain? :)
geposted Wed 30 Dec 15 @ 7:42 am
Unless you use a wrong audio setup, the same case should be with VirtualDj as well. All way to the right you should hear the master mix, all way to to the left you should hear whickever deck(s) you have PFL assigned to.
geposted Wed 30 Dec 15 @ 10:00 am
Agreed, NS7 works great. Here is my config
geposted Wed 30 Dec 15 @ 2:51 pm
Yes i use exactly the same setup.But on the right i hear 1 deck and on the left second deck.There is no master anywhere?
geposted Thu 31 Dec 15 @ 1:27 pm
What sound card or controller are you using?
geposted Sat 02 Jan 16 @ 1:38 am
Numark NS7 controller
geposted Sat 02 Jan 16 @ 12:42 pm
I'm sorry, I did not realize you are the OP, I did not see the user numbers were the same. You are not able to see the master option in the pull down? Are you using Version 7 or 8?
geposted Sun 03 Jan 16 @ 2:18 am
Give us a screen shot of your sound setup
geposted Tue 05 Jan 16 @ 6:46 am
