the trackpad of my laptop died, I bought an external logitech usb mouse but i can't move it as fast
i change the speed of the wheel, and it works everywhere, browsing the internet or my HD, but when I browse my virtual dj playlists, it doesn't matter what settings I use, it only moves two likes at a time and then stops, can't accelerate it and keep it moving like I did with my trackpad, I wish i could move at least 6 lines at a time, to get to the last songs in my playlists takes forever.
does anyone know anything about this?
wish i could change the size of the scroll bar too.
geposted Tue 29 Dec 15 @ 10:45 pm
i don't think so because i'm using the same one, but could it be modified inside the skin?
geposted Tue 29 Dec 15 @ 11:03 pm
Most likely you will need to install the software for your mouse from logitech and tweak it's settings there. Some mice completely ignore Windows settings. I know because I have a Razor and you can't tweak anything without installing it's own drivers/software.
So please visit Logitech website and check if there's any software for your mouse (Usually Logitech SetPoint)
geposted Wed 30 Dec 15 @ 5:38 am
i installed setpoint, logitech software, but it does nothing inside virtualdj, works everywhere else, weird.
geposted Wed 30 Dec 15 @ 2:54 pm
ok, this is getting really weird.
I have a microsoft mouse, and acceleration works perfect.
bought the logitech, it doesn't work, only two lines at a time, with or without it's own software
bought a HP mouse, doesn't have software, just w10 drivers... same thing, only two lines, scrolling down a huge playlists takes forever.
when i use the trackpad in my laptop the acceleration is even faster and if I do it fast enough it keeps moving even when my fingers are no longer touching the trackpad.
any clue what's going on?
geposted Tue 05 Jan 16 @ 3:34 pm
now it gets funny
i installed this thing:
http://sourceforge.net/projects/mwaccelerator/
and now it works! acceleration is back with the other mouses too.
geposted Tue 05 Jan 16 @ 3:55 pm
