Topic: Denon DJ MC4000 - 4 sampler pads
With Denon DJ MC4000 controller you can use the sampler pad to trigger the first 4 samples in the sampler_bank that is in view.
Assuming you have more than 4 samples in the current bank how do you trigger them using this controller?
Help.
geposted Fri 01 Jan 16 @ 8:09 pm
Without knowing this controller, I would go for a shift action.
There is a VDJ8 operation guide available for the default mappings of this controller:
https://virtualdj.com/documents/Denon%20MC4000%20-%20VirtualDJ%208%20Operation%20Guide.pdf
The sampler stuff is on page 7
At a glance it doesn't look like you can access more than the 4 (shift stops the sample).
I think that's the same for most controllers. When you run out of buttons, that's the end of it
But you can of course change the mappings in any way you want in the settings
Or you can have more banks
You can also use F1-F12 on the keyboard to play the samples
Can't you use the pads on the other deck as samples 5 -8, with the samples going to output?
Happy New Year.
Thanks for that link Klaus, it helped me to understand the VDJ8 effects on my XDJ R1 (no manual !).
