I have mapped this on a button
Skin_panel 'master' on ? Record : skin_panel 'master' on
If im on skin panel mixer and if I press the button I have mapped it will go to skin panel master and hit record and it will start recording when it senses audio but if I go back to skin panel mixer and I want to check the length of the mix recording I will press the button I have mapped and it will go to skin panel master but it will stop recording the mix what is the script to map if I want to press the button to go to skin panel master and press it again to record and if im on mixer panel to press it and go to master but not stopping the mix being recording until I press it againg
geposted Mon 04 Jan 16 @ 3:50 am
Not sure nor able to test but there maybe a bug here, as I read it recording should only stop if master panel is visible.
geposted Mon 04 Jan 16 @ 4:43 am
you map it on what, controller, keyboard...?
geposted Mon 04 Jan 16 @ 6:56 pm
seems like the record action is executed on up (button release), so try this...
skin_panel 'mastermixer' on ? down ? record : nothing : skin_panel 'mastermixer' on
geposted Mon 04 Jan 16 @ 7:14 pm
