I have mapped 4 buttons for loops this is my script button 4 cue 9 set ? Delete_cue 9 & set_cue 9 : loop 1 while_pressed & set_cue 9
Button 3 loop 0.5 while_pressed
Button 2 loop 0.125 while_pressed
Button 1 loop 0.25 while_pressed
If I press button 4 then 3 then 2 then 1 when button 1 is released it loops out so it does what it supost to do
But if I button 4 then 3 then 4 when 4 is released it stays in the loop which is one beat it does not loop out like it should do because the loop is only active while is pressed
Im using vdj 8 on windows 7 any help please reply thank you
geposted Thu 07 Jan 16 @ 4:25 pm
Cue 9 set?
Idt that's correct script, try
Cue 9?
Cue 9?
geposted Thu 07 Jan 16 @ 10:40 pm
I will try thank you
geposted Fri 08 Jan 16 @ 1:18 am
in your script, why put cue 9?
I don't understand what you want do!
geposted Fri 08 Jan 16 @ 1:44 am
Thanks locodog it worked like a champ
I need it to set cue 9 because thats an extra cue that I use when im aplying effects and chopping song so I can return to where I started and it sounds good because people will tell the difference normal play and what you just did
geposted Fri 08 Jan 16 @ 2:55 pm
