Hi guys, been a digital dj for years, and I love it. Now I want turntables. I have a windows pc running Windows 7 64-bit and I was thinking getting stanton st150s with the thud rumble mixer. What is the best interface for me?
geposted Thu 07 Jan 16 @ 10:02 pm
Are you set on that mixer?
I ask because I use CDJ's timecoded into a DJM-600 through a Native Instruments Audio 6 interface. While I love the interface, the next mixer I look at will have an interface built in.
geposted Fri 08 Jan 16 @ 12:00 am
On a Windows computer a Rane SL1 will work but on a Mac a Rane SL1 will not work. So if you want to go the Serato compatible road get a SL2 or better if you can.
I have been looking into the Native Instruments side as well and depending on how many tables you want to hook up a the Audio 6 or 10 should work. Personally I am looking around for used stuff all the time as guys buy equipment and "Don't have time anymore" so they sell their failed dreams.
I'm sure there are a few others but these 2 options have the numbers behind them.
geposted Wed 13 Jan 16 @ 5:36 pm
