im sure this has been asked before but i can not find the answer when i load vdj7 all my music is there but when i load vdj8 half my music is missing i have analysed my music in vdj8 etc but still no joy , ie when using vdj7 if i search for HOZIER, TAKE ME TO CHURCH its there but when i search the same song and artist in vdj8 there are no results if anyone help please thanks
geposted Fri 08 Jan 16 @ 9:20 pm
vdj 7 and vdj 8 have separate databases. If you add something in 7 it won't be in 8.
To have all your vdj7 stuff, delete the vdj8 database and run the program and it will take all the info from the vdj7 database and create a new vdj8 database.
But remember, if you add anything on 7 afterwards, it won't be in 8.
at this point, vdj8 is pretty stable for me. I have abandoned 7 to avoid all confusion.
geposted Fri 08 Jan 16 @ 9:36 pm
thanks for the reply but i have been using vdj8 for some time now and love it but when i buy and download new music it shows up in vdj7 but not vdj8 thanks
geposted Fri 08 Jan 16 @ 9:49 pm
It shows up? How exactly are you adding your new music to the database? Do you have both VDJ 7 and VDJ 8 set to automatically add new tracks when you browse (in VDJ) to a folder?
geposted Sat 09 Jan 16 @ 5:28 pm
