Somehow (probably through dragging a folder in twice) I've ended up with hundreds of duplicate entries in a Virtual Folder (they only appear once in the Database). I've opened up the vdj file in Notepad and there are, in separate parts of the file, 2 entries for loads of songs. Is there an easy way to delete the duplicates without manually going through them one by one?
geposted Sun 10 Jan 16 @ 11:33 am
you can thru automix
geposted Sat 16 Jan 16 @ 8:00 am
